Regrettable Engine strip down !!!! I think " Follow up". But it's not over.
Re: Regrettable Engine strip down !!!! I think " Follow up". But it's not over.
8 months 1 week ago - 8 months 1 week ago
Pretty sure what you're looking at here is oil that was sitting on the top ring and as you rolled the pistons down, that oil slid down the cylinder walls. If you wiped down the cylinder walls and rolled the pistons through, the cylinder walls would be oil free. (should be anyways.)
Oil in the airbox can only come from oil vapors that condensed in the airbox from the PCV system. That much vapor coming from the PCV is generated by blowby around the piston rings. But again, you're compression numbers tell a completely different story. I'm at a loss.
Last edit: 8 months 1 week ago by Kawboy.
- z13phil
8 months 1 week ago
Hi Kawboy, I have wiped the bore's and every time the pistons go up and down its like a oil pump. Particularly on #1-2-6
8 months 1 week ago
Wierd. Only one thing left to do. Pull the cylinder block and take it from there. Can't wait to here what you find.
8 months 1 week ago
I've been thinking this thru and am also coming-up "blank".
I do have a thought about trying to prove more definitively as to from where specifically and how, that oil is getting to your piston tops. If you are getting oil simply by turning the engine over by hand then Pressurize the oil system with air; starting from "0" P.S.I. and gradually increasing to a few lbs, using a regulator. The "boost" might better prove the source(s)
- z13phil
8 months 1 week ago
Yes Kawboy, this is under way. But at a stand still at the moment,
This is not like working on mt Z1R !!!! Just worried about the the nylon bevel gear on that shaft that goes to the small timing sprocket.
Will they fall off as i withdraw the shaft. O lord how do they go back on afterwards ?
8 months 1 week ago
Just follow the Factory Service Manual and you'll be fine. It's pretty straight forward.
Time to create page: 0.098 seconds
