  • Daro
  • Daro's Avatar
9 years 2 days ago
#17576
Hi StanG not long ago I did what Tyler said, I got some after market gasket and use Permatex seal on it around water channels on top and bottom of it. Got first 250 km. done but its holding perfect.
  • StanG's Avatar Topic Author
9 years 2 days ago
#17577
I already have a set of stainless bolts for all the engine covers, including this oil pan :)
9 years 2 days ago
#17578
Yesterday I took care of the starter. It looked fine on the outside when mounted on the engine. Not so hot when removed... It was seized. I got it turn after gently back and forth, but of course it had to be taken apart.
Here is the culprit - rust.
The other side.
Lots of carbon from the brushes. They are a bit short but still usable.
All cleaned, ready for reassemble.
9 years 2 days ago - 9 years 2 days ago
#17580
All back in one piece.
I completely removed the rust very carefully with wire brush and sand paper. Then some polishing with Autosol metal polish followed by spraying all with electrical contact cleaner. All shiny inside-out. On bare metal I applied ACF-50 aircraft anti-corrosion formula.
The casing was sanded and sprayed with 65% zinc rich galvanizing coating. Very sturdy. Both ends of casing polished aluminum and rubbed with ACF-50 for protection.
Inside bearings cleaned and greased.
Turns beautifully, ready to go!
It's easy to disassemble and service the starter. I replaced the end seal but left the two casing big thin o-rings on. If I find new brushes replacements in the future I will exchange them. The current will work well for in the meantime.
Last edit: 9 years 2 days ago by StanG.
9 years 2 days ago
#17581
Looking good there Mister !! Nice work.
9 years 2 days ago
#17582
Thank you Daro. I already ordered another head gasket directly from local Kawasaki dealership. I am going to pick it up today, and of course open the package and see how it looks. I got a refund for the other one and got to keep it. So I have two back up now plus this one coming. I will apply the sealant you suggested even if the seals on the coming gasket look good. Keep me updated please how it's holding up!
