AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
- zoso
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
12 years 5 months ago
Hi Beertad
Yes that's exactly what you do. If you can't be bothered to make one you can buy it already made up from MCG in Germany.
cheers
cheers
- Mikez
Exactly those negative leads are just ground connections. They can all be spliced into one wire or three-into-one if that makes more sense. Much more important that the positive wires are set up correctly. Some spare wire and solder is all that is needed
As the others before have correctly replied, its making 3 connections from the one wire (one to each coil).
I much prefer to solder as many contacts on a bike as I can to ensure a good clean signal & then cover with glue lined heat shrink tube to make it 100% water-proof.
Some say that's a bit "over the top" but it makes sure I never have to stand at the side of the road waiting for a recovery truck !!
Regards
Pete F.
Regards
Pete F.
- Tad
thanks guys
just got to find some coils in the uk now.
would prefer new if anyone knows a supplier ?
Tad
- zoso
12 years 5 months agoPlease Log in or Create an account to join the conversation.
- zoso
