7 years 11 months ago
Don't see any mention of the ignition triggers ? (being correctly connected to fire the correct ignition coil)
- Tuomas
7 years 11 months ago - 7 years 11 months agoWe measured coil pickups with multimeters, and the reading shows when triggered so they work. It is very difficult to determine which coil pickup triggers each coil. Visible wire colors are all the same near pickups.scotch wrote: Don't see any mention of the ignition triggers ? (being correctly connected to fire the correct ignition coil)
Trigger (primary) wires to coils are stock as they reach wire terminals only one way.
We will try to arrange wires one more time. According to picture, we have them totally wrong. Thank You for good picture!!
Last edit: 7 years 11 months ago by Tuomas.
Sounds like someone has rewired replacement ignition triggers (unless this year is different) and this could be confusing ! Otherwise the schematic is very clear.... wire color wise.
7 years 11 months ago - 7 years 11 months agoTuomas wrote: Flipped spark plug wires from coils, did not make any difference.
They are now connected this way:
1+6 wires go to right side coil
2+5 wires go to left side coil
3+4 wires go to upper coil
Is this correct?
All 'wire length' issues aside, it's not the position of the coil that matters; you need to ensure you have the right colour coded wires hooked up to the coil's input.
Last edit: 7 years 11 months ago by Bucko.
- Tuomas
We have wiring diagram but it does not specify colours to coils (blue, green and black) vs. colours to coil pickups. But they are on same order as they were when this bike ran.
7 years 11 months agoTrue enough, the wiring diagram leaves you with little specific information. It is in the manual under the service inspection areas. I've copied the relevant sources for youTuomas wrote: We have wiring diagram but it does not specify colours to coils (blue, green and black) vs. colours to coil pickups. But they are on same order as they were when this bike ran.
The black/blue leads from the pick up coils are the trigger wires for the 1-6 coil
The Yellow/red are for the 2-5 coil
The green/light green are for the 3-4 coil.
