5 years 10 months ago
Kawboy wrote: And this is a prime example why I choose to be part of a Forum after retiring 12 years ago. Keeps the brain in check. So maybe a senior but not ready for seniors moments quite yet (maybe next week? ).;)
You're doing great! And Sooo many Thank You's to this forum and members!:) :)
  • Stiggy
  • Stiggy's Avatar
  • March 1961
I assume the regulator is in the instrument cluster?
On my ZG1300 it is under the fuel tank iirc.
1985 ZG1300 dfi
Last edit: 5 years 10 months ago by Stiggy.
As I understand it, the job of that voltage regulator is to supply a constant & stable 7 volts DC, irrespective of battery voltage, to the fuel & temperature gauges, so that the needles don't move with the constantly changing battery voltage?
That sums it up !
2021-01-15 Kz1300 Cooling Stress Test
Been chasing an overheating problem on the KZ..
It's January, and all rides to date have been in high 50 to low 60F ambient conditions.
Weather forecast is low 80's in the south county of San Luis Obispo.
Let's go there then slog around on city streets to see what happens?
Fully prepared with AAA, health insurance, and credit cards!
I will say that after all the work, she starts instantly and sounds good at idle.
In Atascadero CA to send incorrect delivered parts back to PartZilla.
Another view.
Something werid with charging system now. This 12.1 will pop up instantly sometimes, other times slooowly creeps back to 14.9. BTW, the voltmeter is 0.5 low.
More importantly, the temp gauge is at high end of normal zone, but over, and I'm slogging along in first gear going through town.. A good sign!
The hottest it got. I'll take that for now.
Unfortunately, had to cut the ride short as apparently my charging system is directly inversely propotional to ambient temps AND the fuel tank isn't venting
adequately.. the bike started running real rough and smell of gasoline. Opened tank cap and Whooosh... so pressure is overriding float/needle and flooding the engine.
MPG
Temps
Notes:
Charging system needs work, VDC drops below acceptable levels when hot and is intermitte
Cooling seems to be OK enough given I'll not be riding on hot days in heavy traffic anymore
Tank is building pressure when hot
Ran two tanks of heavy dosed Yamaha Ring Free
dcarver220b wrote: Charging system needs work, VDC drops below acceptable levels when hot and is intermitte
You've probably checked this already but the alternator connectors are notorious for getting a bit on corrosion on the terminals then overheating causing them to be intermittent and reducing alternator output.
Also not weird for the alternator windings be become a bit funking and when they heat up and expand they short out or open circuit.
The following user(s) said Thank You: dcarver220b, Kawboy
