  • Bar
  • Bar's Avatar Topic Author
5 years 7 months ago
#28800
another question for the fuel injection experts
since I am removing the airbox
what the best to do with the air temperature sensor?
Disconnect, add a resistor or find a place between the new air filters ?
Thank you
Eran
1984 Kawasaki Voyager
2002 Honda CBR954
  • Phil
  • Phil's Avatar
#28804
I rigged a bracket for it near the air intake. You could just attach it somewhere near the air intake as all it's measuring is the ambient air temperature going into the engine. Just don't attach it near any heat sources as that will give false readings.
  • Stiggy
  • Stiggy's Avatar
5 years 7 months ago - 5 years 7 months ago
#28806
I would be tempted to fit a discrete working sensor. Buy a 2k Ntc bead thermistor solder your leads to it. They are tiny... only about a 3mm bead so will go nicely in some heatshrink tube. Then mount discretely against air filter.
1985 ZG1300 dfi
Last edit: 5 years 7 months ago by Stiggy.
  • Bar
#28826
I'm looking for a fuel gauges sender for the Voyager
does anyone installed any aftermarket or fit anything that work?
Thanks,
Eran
2002 Honda CBR954
  • Bar
#28843
the plan for today was to get the bike on the road for a test drive
I did put it on the road but having an issue with the clutch
It look like its not engaging all the way, i may need to extend the clutch push screw.
for now I will go back to cable for testing
It is not 100% done yet but this will be the final look
2002 Honda CBR954
#28844
It’s looking superb. Lots of interesting details .Well done!
Time to create page: 0.150 seconds
