Fuel tank blues
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Fuel tank blues
10 years 2 months ago
#14113
Mightyzod wrote: Zed_thirteen:
You mention that you think a ZG1300 might fit my 80B model 1300, but it lacks a fuel pressure return. Since my bike is not injected, would such a tank work on mine? I ask because I have found a decent deal on a ZG1300 tank.
Is there any way to verify the fit?
Big thanks,
MZ
Hi MZ
I was only trying to point out the possible differences and which tank would fit which bike. I think you can put a tank from an injected model onto a carb model but if you put a tank from a carb model onto an injected model then there will be nowhere for the return fuel.
In my opinion your tank is an original B2 tank, which is a carb model, and should fit any carb model frame - KZ/Z1300 A1 to A5 (I think) or the KZ1300-B2.
Just one other thought - I'm sure you are but... You are routing the fuel line down past the left of the frame rail and not trying to pass it over any of the frame rails?
  • zed_thirteen
Re: Fuel tank blues
#14114
when I install my tank (a B2 tank on B2 frame) I think I always lay it on the frame behind the front rubber mounts with the rear bolt hole at the correct level and then slide it forward on to the rubber mounts. The last 1cm or 2cm is always tight though
  • Mightyzod
  • Mightyzod's Avatar Topic Author
Re: Fuel tank blues
#14123
Excellent. I think, after all of the measuring and conjecture, I cam sum it up as...right tank, but screwed up. I am working on picking up another tank, which brings up another question (surprise). I notice that some tanks have the Kawasaki emblem mounted directly to the tank, while others are placed on those huge mounts on the tank. I personally love the mounts for the badges, but would like to know why the difference.
As always, my deepest appreciation for all of the help.
MZ
  • Ledkz1300
  • Ledkz1300's Avatar
Re: Fuel tank blues
#14126
Different badges and setups for different years and models. The shapes of the tanks are different as well. My 79/80 had the raised chrome mounts with the badges. Tank bulges out over the engine and is more squared off. My 81 has more of a rounded tank and the badge is mounted directly on the tank. The tanks are still interchangeable.
  • Tuckabag
  • Tuckabag's Avatar
Re: Fuel tank blues
#14128
If you are certain that the tank is bulged underneath and are willing to go down the replacement tank road, why not try giving the current tank some "persuasion" to get it to fit?
Personally if I'd got to the point of no return, I'd give that a crack, nothing lost if you bugger the tank.
I would mount some blue-tack or similar in thin strips where I suspected the tank was fouling, mount it up and then give it a bit of a tap in the offending areas. Can't hurt if you're willing to junk it anyway.
  • hillsy
  • hillsy's Avatar
Re: Fuel tank blues
#14133
Tuckabag wrote: I would mount some blue-tack or similar in thin strips where I suspected the tank was fouling, mount it up and then give it a bit of a tap in the offending areas. Can't hurt if you're willing to junk it anyway.
That's a great idea. That way you'll see where it is hitting the frame.
