Water pump seal internal housing
Re: Water pump seal internal housing
3 years 6 months ago
Used a couple of sockets. It worked.
[img
x
[img
Put inner piece in freezer for an hour, heated aluminum outer piece to 325F in oven.
Tapped into place using hammer and special Kawasaki fitment tool <socket>.
[img
All done!
[img
Did you calibrate those tools before and after doing the work? it is the nuclear way.
A little off topic but I was the one who created the pre and post verification (calibration) process for critical or high rad work. The instrument would be tested before use (prever) at test points the user would be measuring then when work completed, the instrument would be post verified at the same points. This 'bracketing' of work ensured that should the instrument later be found out of tolerance, the critical use job would not be impacted.
And, yes, the hammer passed both pre and pst ver!
3 years 6 months ago - 3 years 6 months ago
2023-04-18 Kz1300 Water Pump Reassembly Gasket removed. Plastic 'razor' blade is cat's meow.
[img
Old rotating seal removed. It was easily pried out.
[img
x
[img
Cleaned O-Ring landing. Parker O-Ring grease. New O-Ring from z1300.de
[img
New transfer tube, circlip, o-ring. From z1300.de
[img
OEM seal (top two pieces) are supposed to be on piece, like bottom pic.
[img
Last edit: 3 years 6 months ago by dcarver220b.
All clean ready for install. Took care to keep acidic fingers from sealing surface (white area).
[img
x
[img
Gasket from z1300.de not 'purrrfect' but will work.
[img
