Water pump seal internal housing
3 years 6 months ago
When I removed the mechanical seal, the metal surrounding the spring remained in the block. Pic on LHS. The Z1300.de part (center) and Amazon US Seals PS-1000 are a 'unit' meaning the spring and metal sheath are one.
Anyone have words of advice? I didn't recognize this until just now when updating the other post.
Re: Water pump seal internal housing
3 years 6 months ago - 3 years 6 months ago
My best guess would be that the OD of the spring and the ID of the cup are an interference fit and if you were to rotate the spring in the direction it is wound, it will shrink and come out. Looking at the middle seal and the one on the right- the springs are wound opposite to each other, so you would turn one clockwise to reduce the diameter and the other counterclockwise.
that also brings to mind that when looking for a replacement seal, it's probably important that the spring has the same winding. I would think you would want to rotate the seal in the opposite direction to the winding otherwise there might be some chatter in the seal faces as the one face rotates against the stationary face if that seal face was trying to work against the spring. ( I hope that makes sense ??)
Last edit: 3 years 6 months ago by Kawboy.
Red arrows say it all. Lower left arrow is the metal housing that remained in block.
It should have come out as one piece, with the spring and sealing component.
[img
Should look like the center and rhs units, with metal 'cup' surrounding the spring.
I tried to disassemble, remove the spring from does not fit PS-1000 unit... Failure. It must be glued.
Not sure how to proceed to remove the housing from engine block. My only experience with stuff like this a blind seal on motobike countershafts. For that I drilled then used self tapping screws. Two small vice grips and the seal wiggled out.
This one, however.. I don't imagine there's any 'space' or void to drill without damaging engine block. Don't wanna go there..
Only thing I can think of is to carefully use a drift and start mangling, err, I mean 'persuading' the outer lip inwards. Or maybe carefully use a small Dremel?
Looks like Ray used some kind of sealant when he installed the seal, so it's not going to simply wiggle out easily?
Looking for advice please?
Last edit: 3 years 6 months ago by dcarver220b.
Looking at the diagram copied from Partzilla, you need to remove the mechanical seal retainer item #8 from the cylinder head and you should be able to drive out the  mechanical seal from the retainer from the back side. Be CAREFUL how you support the retainer and don't crack it in half. And you're right, the PO glued it in place so I would consider heating it up a bit first to breakdown the glue before attempting to drive out the seal.
I have a bad habit of thinking I know how to do sh#t. Then I followup up by overthinking what I think I know when in reality I don't know sh*t!
Soooo, remembering my favorite nuclear procedure writers mantra, RTFM!
/index.php/attachment/11274
KB, Thanks for putting up with me.
Progress today! After RTFM, discovered the backing plate assembly is removeable.Bought a couple of bolts w' big heads then pulled the assembly out. EzPz when you know how!
[img
x
[img
Some muck. Wish I'd never used stop-leak.
[img
x
[img
The oil seal is sealing.. Going to leave it alone.
[img
Drilled a hole to allow clearance, then pressed the seal housing out..
Almost 1/2 way out here, but is hitting the wood.
[img
Almost.
Time to create page: 0.115 seconds
