Cam chain tensioner idler
- fineline
5 years 10 months ago
Hi Fellow Z1300 lovers. I'm doing a top end rebuild on my smokey 1979 Z1300. Not to mention, replace the frame... but that's another story. Does my cam chain tensioner idler wheel look ok or would you replace it anyway. It kind of looks ok ish to me. But a more experienced opinion would be great thanks.
- fineline
Re: Cam chain tensioner idler
Your Nylon sprocket is in excellent condition ! Because you have it out, you have two choices. Reinstall it and with some simple care, it'll outlast you. ( Let the next owner worry about it.)
Or: Replace it with the Liska Racing sprocket and never have to worry about it, regardless of who ends up with the bike. Certainly some value in that premise.
If you choose to reinstall the nylon sprocket (seriously) do some research and understand the ramifications of doing so in conjunction with your choice of options for the tensioner, itself.
Someone did a load test on the OEM tensioner spring and stated that the pressure is about 1000grams. The spring tension of a popular option was measured at 2000 grams. ( if I remember this correctly) If you're intuitive, you can see where this comment is going.
Modifying the OEM is easy and safe. My alternative choice would be an aftermarket manual tensioner with NO spring.
I'm waiting on a " Liska Racing" steel sprocket. It'll go in the cupboard along with a complete gasket set and rings; ready for the day I decide to do the top-end.
My original sprocket has some teeth left, even with just under 100,000 K. I attribute it's longevity to common sense in maintaining the OEM tensioner which was converted, way back when(?) AND uses the original spring. The spring could be removed without any concerns. The term "Tensioner" is dubious. All that is needed is an adjustable device that removes the slack, which avoids the chain skipping.
- Stiggy
- March 1961
I fitted an alternative spring to my GPZ1100 tensioner , as follows....
Ebay Item number 331459306709 size 85mm long, dia 5.63mm, wire dia 0.63mm material Stainless Steel, R 2.77
It has resulted in a loading as you mention of around 990 grams.
1985 ZG1300 dfi
Last edit: 5 years 10 months ago by Stiggy.
5 years 10 months ago - 5 years 10 months agoStiggy wrote: Someone did a load test on the OEM tensioner spring and stated that the pressure is about 1000grams. The spring tension of a popular option was measured at 2000 grams. ( if I remember this correctly) If you're intuitive, you can see where this comment is going.
STIGGY,
That is very valuable and useful information on the spring you have found available.
Well done and thank you.
Having owned over ten Z1300's over the last 40 years and serviced many more for other owners, I have fitted the GPZ/ZZR1100 Tensioner to all of them and not one has had any issues or wear problems. All have had 10cm cut off the standard spring, but your find does give the tensioner the "stock" level of strength so should silence the "scheptics" .................but then again probably wont as ever !!
The main danger of using a tensioner with no spring, is that if the Nylon Idler Gear or Rubber Gear FAIL (which they often do) then there will be enough "slack" on the cam chain for it to jump a link on the cams and......................well the rest you can guess !
Spring loaded tensioners are definitely the safest and best.
Regards
Last edit: 5 years 10 months ago by strate6.
- fineline
Thanks Scotch, that's the news I was hoping for. I think I will refit it then. I have the OEM tensioner which was modified so it can be locked in position. I bought and fitted a manual tensioner at one stage, but just didn't trust myself to get the right tension so swapped back to the modified OEM one. I trust Kawasaki's spring rate more than my best guess.
It looks like they have new nylon sprockets for sale at MCG in Germany for 79 euros (if I'm looking at the right part). If I got the thumbs down on mine I might have gone that route.
