Cam chain tensioner idler
- rdurost
Re: Cam chain tensioner idler
5 years 5 months ago
Hey Scotch. what's your procedure? Without a specific torque figure, I just (crucially) slipped back the O-ring on my manual tensioner and turned in the screw until it was a "firm finger" tight. Without taking the O-ring out of the scenario, there is no possibility of doing it by feel.
5 years 5 months ago - 5 years 5 months ago
I left the original spring in my CCT. Just added the "back-up" bolt and a locking nut.
Engine idling at 1000, I back-off the locking nut, and "feel" for the sprocket and chain meshing. Too loose and I can feel the tensioner "spanking" the end of the adjusting bolt. I adjust so I can't feel that.
The OEM spring creates the contact pressure. The bolt and nut ensures the "guts" can't back-off. I've still got teeth on my Nylon sprocket at 91,000K. Also have a LISKA gear, when it's time !
You accomplish nothing by running the CCT tight.......other then wearing-out your nylon gear, faster. Adjust the bolt with fingers, only.
Last edit: 5 years 5 months ago by scotch.
Time to create page: 0.075 seconds
