Hydraulic Clutch Converstion
Re: Hydraulic Clutch Converstion
5 years 5 months ago - 5 years 5 months ago
www.kz1300.com/index.php/forum/suspensio...draulic-clutch#24364
I have since removed the small shim-plate as I determined it wasn't required, after-all.
Last edit: 5 years 5 months ago by scotch.
  • SteveSmith
  • SteveSmith's Avatar
Hi, I have all the parts and am just getting all my duck lined up ready to start cutting.
I understand I'll need to fill out the inside of the slaves piston with a shaped piece of metal, no problem there and I'm thinking I'll 'gorilla glue' that in place.
The bit I'm uncertain with is that the adjuster screw actually screws into a piece behind the casing, and it's travel is restricted to about 3/8" maybe?
Do I just leave all that gubbins in place, remove the nut, washer and 'L' shaped lever?
Cover me guys, I'm going in :-)
1979 KZ1300-A1
Time to create page: 0.079 seconds
