8 years 4 months ago
Nice work Stan. I've never used and easy out that didn't break.
This was an easy one because all was clean and fresh. But I did recently do extraction of one really old and rusty one from the collector. I got a flex drill extension and had to do it at a weird angle, since it was straight from the underside of the bike. All went well, but than planning the removal of the bike, I had to remove all the exhaust system anyway! So, all this work could had been done actually comfortably on the table. But it was a good practice, no regrets.
I've broken a few extractors as well. I had no access or couldn't use a torch, or acetylene, and that would had made it much easier. It's a real 'bitch' to have a broken off extractor tip stuck in the bolt... But I also have a tool for that. Doesn't work for all though. Many times it comes down to a hammer and small screw drivers to loosen it up.
But in those extreme situations, the best bet (if you have a good eye and a steady hand) is to drill the bolt out and then first try to use tiny chisels trying to break away the remaining mesh like left over of a thread, or when you see the underlying threads, use a proper tap to re-thread the hole. It should catch the existing groves and clean everything.
8 years 3 months ago
In the process of preparing my bike to move I will need to use a rear wheel stand. There are many different online even on Craigslist, amazon, Fort9 etc., but hard to make up my mind.
Do you guys have a favorite one for our heavy bikes? (and available in Canada)
WHAT'S GOING ON? I CAN'T POST ANY PHOTOS.
- RChaloner
Stan that's a new automatic feature, because your bike is now too shiney and new looking and it's depressing me!!! ; )
1979 KZ1300 A1
I think so! hhaha
Maybe there is just limited space for uploads. Hope that can be corrected or, stating the obvious, there will be no more photos from me to see.
Last edit: 8 years 3 months ago by StanG.
Time to create page: 0.233 seconds
