Front brake master cylinder
- Burto
3 months 2 days ago
How many holes should my master cylinder have in its reservoir base? I purchased one from ebay and it only has one hole in it, and I cant get any brake fluid to the brakes!,I believe it should have 2 holes in it but do not have the original to compare it with. it does have what appears to be another hole that has been filled? I've honed out the sleeve and re-furbished the piston etc so all that is good, but when I squeeze the lever ....nothing no fluid whatsoever.
Re: Front brake master cylinder
3 months 2 days ago - 3 months 2 days ago
I did a search in the old posts and found a pic showing 2 holes in the master cylinder. They appear to be different diameters.
StanG's 1982 rebuild post # 18896
The "Search" tab is an invaluable resource for finding answers to many repetitive questions. I searched " Front Brake Master Cylinder" and set the timeline to "Any Date" and changed the order to "Increasing Order" which shows the relevant posts from oldest to newest.
Last edit: 3 months 2 days ago by Kawboy.
- Burto
3 months 2 days ago
Thanks for that Kawboy, I shall drill out the second hole tomorrow and see how we go.
3 months 2 days ago
Just make sure you remove the burr that the drill will leave in the cylinder bore, otherwise you'll cut the lip on the plunger u-cup.
The following user(s) said Thank You: Burto
Time to create page: 0.092 seconds
