DEEP SUMP (Oil Pan) Details
Re: DEEP SUMP (Oil Pan) Details
#1905
Just to add further: My '80 1300 (sr.# KZT30A-009997 Canadian) has "5.3" cast into on my clutch-case and having owned it since new I can confirm the 5.3 is correct. My fuel-tank holds 19 (Canadian/imperial) litres. Just finished re-calibrating my fuel-gauge and needed to fill and empty the tank a few times so the 19 litres to within 1/2" of the bottom of the fill neck is accurate. Took another look at the deep-sump option but I only have 1/2" of vertical space between it and the DG header collector. I am sceptical the deep sump will fit. ( my drain-plug faces forward).
Last edit: 12 years 8 months ago by scotch.
  • tackelhappy
  • tackelhappy's Avatar
#1926
Mike, I'm going from memory here about the sump etc. David Ewing had posted pictures on the old forum of the voyager sump and header pipes to show how they attached on the voyager- maybe his own bike. Maybe the parts diagram may show the difference between the header pipes mounting system of both models or there could be owners here on this forum that own both bikes and could take a look.
Voyager parts don't come up on ebay that often, but the oil pan I saw several weeks ago was around $150.00.
I've wonder too if anyone has bought the weber carb conversion-- it does give several choices now -stick with what you have , convert to the voyager fuel injection or six carbs from Japan.
  • Mikez
  • Mikez's Avatar
#1960
When I looked I remember thinking that the voyager pipes and sump were cheaper or easier to find than the kz equivalent which was why I was looking into it at the time. If that allows me to fit a voyager sump which is also available right now on ebay then that could be a pretty big plus!
When I googled weber carbs it looks like they are used in Jeeps and the like so parts would likely be readily available. One of them on ebay can vary in price but can be had at 250ish new for a dual barrel one. Kind of cheap in my opinion.
#1962
MikeZ
Interested to know how it goes when you get around to doing that WEBER carb mod.
There was a bloke in the early 80's close to where I lived as a boy who had a Z1300 & modified it to take two WEBER carbs........god know how !
The local bikers met at a cafe out in the open & he would go past at silly speeds...........with 2 foot orange flames coming out of each exhaust.....pretty impressive thing to see I can tell you. !
  • Mikez
  • Mikez's Avatar
#1964
Haha yeah that sounds badass indeed! Whilst googling this mod I did come across someone who had two weber carbs set up and I really liked the way he did it because those two dual barreled carbs were affixed to the engine with very short mounts instead of a 6 into 2 pipe. I'll have to find the pictures again and post the link.
Without a reasonable way to machine/source the carb to motor mounts it might be out of reach for me. Will keep looking though.
  • Mikez
  • Mikez's Avatar
#1965
Ok yeah I found it wasn't as hard as I thought lol :).
www.autoshoppingcenter.com/classic/parts/fiat_kawa.html
The carbs/intake manifold would be that's needed but the manifold looks to be specially made. Anyone have the gumption to contact them about it? lol
from the site:
"this engine # RZT30AE 012796 will do the job : 6 cylinder, 1300 cc 127 horses
and to give a little more pep. : we install two 42DCOE Weber Carburetor with a very special / computerized intake manifold
If you need a engine like this, for your project , please contact us"
Last edit: 12 years 8 months ago by Mikez.
