Engine Guards for '82 KZ1300?
  • rdurost
6 years 1 month ago
#27803
Would engine guards for an '85 ZN1300 Voyager fit my A4?
Re: Engine Guards for '82 KZ1300?
6 years 1 month ago
#27808
Should do as I believe Engine Mounting Points are in the same position on all 1300/6 models.??
  • rdurost
6 years 1 month ago
#27814
Unfortunately, it looks like the situation is even more muddled than I had feared. From an eBay offering of some $500(!) units from Italy:
"Will fit 79-80-81 model This set will not fit 82 model." Even different years of 1300 sport versions don't necessarily interchange!
I can't post eBay listings on here for some reason, but the item number is 164344282214 if you want to check it out.
  • stocktoy
  • stocktoy's Avatar
#27816
No eBay APP ID and/or Cert ID defined in Kunena configuration
does this work?
Nope I guess not
Last edit: 6 years 1 month ago by stocktoy.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
6 years 1 month ago
#27819
I'm curious if it has to do with the different "stuff" Kawasaki decided to hang off the crankshaft at different points in the model run. I know the A3 had the ignition pickups in the right side, and certain later models added a second stator on the left (with an appropriately thicker sidecover to go over it).
  • LareNurminen
  • LareNurminen's Avatar
6 years 1 month ago
#27820
The A1-A2-A3 versions of KZ1300 can be fitted with the same engine guards. A4 needs spacers on the left side to fit the "standard" guards. I have them on both of my A4s.
The European Z1300s can be fitted with standard guards.
The ignition model ZG1300 requires wider guards.
