it's happened again !!
  • kza13
  • kza13's Avatar Topic Author
11 years 2 months ago - 11 years 2 months ago
#8594
My bloody tacho cable has broken again, this one isn't that old, and I made sure the cable was well lubricated when I put it in, it was a new part, this will be the second one in a couple of years, they just seem to screw off down near where it goes into the tappet cover, wonder if it has to do with the "S" shape it ends up being when putting it in, maybe a bit shorter cable would be better ??, oh well another browse on e-bay to get a NOS part, never like the reproduction ones. Does anyone run it differently than out of the head and up to the tacho, would love to find a bit longer path to straighten out the cable a bit, cheers Pete.
Last edit: 11 years 2 months ago by kza13.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: it's happened again !!
#8595
This kind of threw me for a bit when I was putting my 1300 together. How are you routing it?
For me, the cable ran straight up out of the engine, outside the first (horizontal) frame member it hits. The only section I rant it INSIDE the frame was the small section shared by the upper radiator hose. Then, it curved straight up, through the assorted wiring and whatnot near the headlight and brackets, to the gauges.
I do admit, it's still a pretty severe routing for a cable. Mine's worked for 30 miles, but then again... (it's only 30 miles). Was this aftermarket, or a stock cable?
Kind of hard to straighten it out longer than this, without introducing more loops and whorls that (I would imagine) would make things worse.
  • RickG
  • RickG's Avatar
#8598
Make sure the drive tang isn't bent a tad you will see it wobbling when running. I havent seen a Z1300 do it but have seen quite a few Hondas do it and having it run away at an angle as it exits the drive is definately not good.
  • Lucien-Harpress
#8599
My problem was, initially, it wasn't enraged in the drive fully. Apparently, the cable is short enough that that it can be above the drive gear/shaft on the head/valve cover, and still engage in the gauge fully.
Basically? Set the cable in the engine first, turn the motor over a bit (so you know it's spinning/working), THEN screw it into the gauge cluster.
(I can get a photo of my routing, if you want it.)
  • paulb
  • paulb's Avatar
#8602
Hi
had the same issue with mine and replaced the cable a couple of times but it turned out to be the tacho had gummed up over the years and although it was still turning appeared to be putting too much of a strain on the cable once it was cleaned issue disappeared
paulb
  • Torque59
  • Torque59's Avatar
#8607
I had a similar experience with my bike. I had the gauges serviced at a place on Evans Rd, Salisbury. They said it was just as well as one of the bearings was starting to seize up which would have caused cables to break and other issues. I can only imagine that yours may have a similar problem. If you like I can PM you the name, address and phone number.
Cheers
Time to create page: 0.233 seconds
