Valve adjustment
  • Kawa2626
  • Kawa2626's Avatar Topic Author
Valve adjustment
5 years 5 months ago
Hi, I’ve been trying to get my 79 KZ1300 road worthy. Haven’t had any luck finding a mechanic familiar with  the bike. Any help would be appreciated! Zip code 11782
Re: Valve adjustment
Have you considered doing the work yourself with the aid of the factory service manual and the expert guidance available on this website?
  • Kawa2626
As a matter of fact I have considered it. I have the manual, new gasket and caps. I understand there is a special tool involved. Definitely would be would need help along the way.
Thanks,
  • Kawa2626
I did consider it. I have new gasket and caps. Isn’t a special tool involved, and are shims easily available?
Thanks
29mm valve shims  fit many makes and models range from 2.00mm - 3.10mm. Some dealerships used to offer shim swapping for a minimal price. Take them the shims you don't need and get the ones you do. Alternatively, keep the old ones for possible shim changing later and buy new ones for $9.00 a piece??
Valve shim adjusting tool   $10.97 US plus shipping.
  • Kawa2626
5 years 4 months ago
When adjusting valves at the different crank positions do you do all the exhaust at one time and move crank and do all intake?
