Head gasket
Re: Head gasket
4 years 11 months ago - 4 years 11 months ago
I guess you’ve run out of metal to polish
It's not the polish I'm running out of. I think I'm running outta chrome on my headers !
I forgot to include the most important aspect of the "panel" :
Last edit: 4 years 11 months ago by scotch.
Re: Head gasket
4 years 10 months ago - 4 years 10 months ago
The second OEM gasket came in....intact ! After torqueing, I let it all sit for three days with coolant in and what a thrill ! Nothing GREEN
on the floor !
Can't express how I felt with the "Italianmetals" leaker, dribbling everywhere .....before the rad-cap was even on. ! Well..... I could..... but the graphic language would have Bill on my case !
Yesterday: Fired up right away but not running well. No Fire in 3&4 so have just finished giving the carbs a cleaning. Been sitting since July 29 with the tank off so I can't say for certain what the issue was. Nothing ugly came out of the center carb but we all know it takes very little to upset everything. Bench sync'ing ( with a vacuum source) is done and just taking a break before they go back on.
Had some interesting things happen along the way with this top-end rebuild but Ill save these little tid-bits for another time when I think we could use a good chuckle !.
Cheers All !
Cheers All !
Last edit: 4 years 10 months ago by scotch.
Re: Head gasket
It remains a mystery as to what was causing the no-fuel issue with the center carb. Had the correct level of fuel in the bowl but wasn't getting to where it needed to go. Nothing solid flushed-out so what ever was causing the blockage dissolved with the Lacquer Thinner. This morning I started the beast and happy to hear all 6 firing ! Sync was right-on so tightened the nuts and did a Color-Tune with minimal adjustments. A small adjustment to the ignition timing was required.
Now just have to wait about 4 months to get out on the road and get the new parts broken-in.
It's been an adventure ! .......to say the least.
Re: Head gasket
I’m glad to hear this , Scotch. But will it really be four months before you get a suitable day for a test ride? I’m impatient to know how much better the bike performs with the valve job and restored compression!
Re: Head gasket
Scotch, normally would not make this offer.... BUT, exceptions are to be made time to time, yes?
Ship the bike to me, at your cost, and I'll break her in for you.
You are welcome HaHa!
- Jafsteph
Re: Head gasket
1 year 11 months ago
Hi all just want your thoughts about my head gasket .i rebuilt the top end a couple of years ago when i completely restored the bike and sadly i don't get much time to use it and just about finished running it in .the bike itself runs loverly and smooth and pulls well .There's no coolant in my oil and i'm not losing any coolant The gasket is OME one ,what i'm getting is some white crystals forming at the back of the engine at the gasket edge /also what feels like oil on my finger. and i'm going to retorque the head So questions are is the factory torque setting right and would you take one nut of at a time and oil the threads which i have never done in the past PS The machine shop checked both head and barrels for warp
Thanks everyone
Thanks everyone
