Piston rings
Re: Piston rings
5 years 1 month ago
"Empathy bud. "
Appreciate the thought !
The "Cruisinimage: rings are not a total loss.  I'll make some "hoop" earing outta them and get some $ back !
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
Re: Piston rings
5 years 1 month ago
"Empathy bud. "
Careful with them hoop earrings Bob. Someone will no doubt accuse you of cultural appropriation! Just Kidding.
If any of our members want to take advantage of Andrew's discounts just send me a PM and I'll give you the code.
Thanks
Re: Piston rings
5 years 1 month ago
Isn't that what Monsanto does to farmers whose fields become "contaminated" with that companies GMO seeds?
Re: Piston rings
5 years 1 month ago
For those who have done their own "work-shop" rebuild......Kudos !
I chose to have a long established and well known machine shop do the required machining for my '80. They shaved the head .003", ground the valve seats and some of the valve stems. The paid very specific attention to the final shim-gap range. The pistons and cyl.'s were mic'd and determined serviceable. The cyl.'s required only a light honing and were done on a SUNAN. The Crapinimage rings were gapped but I won't use them as noted previously so will have to gap the IMD rings when they arrive (this Fri.?).
The cost was $1088.00 (all in) cdn. I estimated $550.00 to buy a Lisle plateau hone, a dial gauge and the micrometers required to do all the measurements. Still would have required the mach.-shop to shave the head ($105.00).
There's more to this type of work then simply running a ball-hone through the bores and lapping valves.
Given those notations made by the machinist ........no idiotic mistakes on my part.....because I'm not a machinist and know my limitations.
Re: Piston rings
5 years 1 month ago
This is what I was referring to.  (One page at a time because any more exceeds the allowed size?)
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Re: Piston rings
5 years 1 month ago - 5 years 1 month ago
The  valve springs were checked also and all passed,  within spec.
Last edit: 5 years 1 month ago by scotch.
Time to create page: 0.106 seconds
