No lights runing
- ninja
No lights runing
12 years 6 months ago
My bike wasn't running for about a year or so, i bought a new battery but the bike has no current on the board, or lights... but closing the circuit of the ignition solenoid the starter runs... where shouldI start looking for the problem?
Pd: sorry about my english, I'm from Argentina and I'm new in the forum
- Toddh
Re: No lights runing
Start by looking at your fuse panel
T.
T.
The following user(s) said Thank You: ninja
- ninja
12 years 5 months ago
I check at the fuse panel under the seat... all fuses work great...
But still no current or lights working...
- RickG
Have you used a meter to check the fuses. I have found many fuses that are not blown but because of age no longer conduct any current.
Is the main key turned on?
- roadhazard
Check the main switch behind the left side cover. It's an anti theft switch. Cuts off power to the ignition. Mine did the same thing. Cleaned it with some contact cleaner and that fixed it.
1980 Kz 1300 b2 touring
1980 kz 1300 A2
1980 kz 1300 A2
- ninja
12 years 5 months agoHhhnmm... I've just visually checked... will check them with a multimeter... thanks!RickG wrote: Have you used a meter to check the fuses. I have found many fuses that are not blown but because of age no longer conduct any current.
