Oil pressure/level switch. 85 zn1300
  • Rage10
  • Rage10's Avatar Topic Author
Re: Oil pressure/level switch. 85 zn1300
7 years 6 days ago
#25166
Welp, the t30 failed. As did a spiral screw extractor. That thing is nice and rounded... next step is to weld a nut to it... but that is a real shit spot to weld to... and it's not like I have a nub sticking out... hmm...
  • Rage10
7 years 6 days ago
#25167
Soldering or brazing a bolt in may be the way to go. I dont think welding is gonna do here
7 years 6 days ago - 7 years 6 days ago
#25168
I'm going to suggest that the plug was put in with Loctite as a thread sealer and some heat would have gone a long way to help with the removal. Seen it too many times so when I get a stuck bolt or screw, the first thing I pull out is the propane torch. Last thing you need is a cracked casing especially around the main oil gallery. Not an easy fix.
Last edit: 7 years 6 days ago by Kawboy.
  • Rage10
7 years 4 days ago
#25179
Oh trust me I used heat. That plug is hella stuck in that hole... also it's a super soft steel. Rounds out really easy.
  • zed_thirteen
  • zed_thirteen's Avatar
7 years 3 days ago
#25180
Not that it helps...
Almost never happens!
  • Rage10
7 years 3 days ago
#25181
Lol I have a baggie with like 5 of those. And like 9-10 broken extractors...
