- Thank you received: 149
Part 2: Complete rebuild 1979 carburettors
- zed_thirteen
Less
More
11 years 4 months ago #7761
by zed_thirteen
Replied by zed_thirteen on topic 1979 Carb Rebuild (Pt 1)
I hope it’s not as bad as that. The white deposits do appear to just wipe off on my finger. A bit of elbow grease will shift most of it. But then there are the areas I cannot see. The slide bores so very little signs of this issue.
Perhaps “Cellulose Thinners” was the wrong term to use. The thinners I used were suitable for thinning cellulose based paints. The composition is: TOLUENE; BUTAN-1OL; CYCLOHEXANE; HEPTANE; N-HEXANE; PROPAN-1-OL; TETRAHYDROFURAN.
Being quite lazy I was hoping for some quick fix by soaking in some sort of detergent (washing up liquid etc.) have even considered putting them in the dishwasher while my wife wasn’t watching.
Less
More
- Thank you received: 1224
11 years 4 months ago #7762
by Kawboy
Replied by Kawboy on topic 1979 Carb Rebuild (Pt 1)
Maybe the pics make it appear worse than it really is and I'm hoping for that.
I've used Autosol for polishing aluminum before and it's amazing. Maybe the elbow grease route will bring them back. A few cotton buffs and a drill or Dermel plus the Autosol.
Check it out - www.autosol.com/
- zed_thirteen
Less
More
11 years 4 months ago #7763
by zed_thirteen
Oh, I'm very familiar with Autosol and Duraglit wadding (silver) - I'm just allergic to hard work
- homer01
Less
More
- Thank you received: 4
11 years 4 months ago #7764
by homer01
Replied by homer01 on topic 1979 Carb Rebuild (Pt 1)
Try and take them to someone that does wet blasting, mine weren't as bad as yours but you would swear they were straight of the shelf the way they came up once done.
- Craig
Less
More
- Thank you received: 41
11 years 4 months ago - 11 years 4 months ago #7765
by Craig
Replied by Craig on topic 1979 Carb Rebuild (Pt 1)
Last edit: 11 years 4 months ago by Craig. Reason: Add picture
Less
More
- Thank you received: 250
11 years 4 months ago #7768
by biltonjim
Replied by biltonjim on topic 1979 Carb Rebuild (Pt 1)
That looks like a PROPER restoration job, Craig. I take my hat off to you. Did you have the brackets, springs etc yellow passivated? the finish looks as new. I wonder if fine bead blasting is a good idea for the carb bodies? i believe it closes up the pores of the metal, therefore reducing the chance of surface degradation. I love it when parts LOOK beautifully finished!
Time to create page: 0.118 seconds
