Too rich
Re: Too rich
1 month 2 weeks ago - 1 month 2 weeks ago
If the throttle slides don't fall under gravity, then there's a problem and likely the diaphragms are hardened. I bought these
KZ1300 diaphragms from Legend Motorcycles
. At the time the locator tab on the outer diameter wasnot in the proper position so in order to use these, I had to cut off the tab. I informed Ledgend that there was a problem and they may have since corrected. The diaphragm material is really subtle and the slides fall really nice.
Last edit: 1 month 2 weeks ago by Kawboy.
- poptheclutch
Re: Too rich
1 month 2 weeks ago
I'm glad those worked out .That's the ones I'll be ordering today. Thanks
Re: Too rich
1 month 2 weeks ago
"The slides seem sluggish to drop when raised by hand."
This not unusual and is typically due to fine scratches on the slides and bore. Easily solved by polishing them. A Dremel with a polishing wheel and a lite compound deals with the bore. Use discretion with the slides so as to not remove the anodized surface.
- baz
Re: Too rich
1 month 2 weeks ago
Hi everyone, has anyone tried the diaphragms Helmut sells on z1300.de? They cost a bit more, but the delivery times would be significantly better. He also has the cut-off valves there.
- poptheclutch
Re: Too rich
1 month 22 hours ago
I received the new diaphragms from Legend in KU. Only took 10 days to get them. I thought that was pretty good. The tabs are indeed not in the correct location. A lil snip and the fit and seem to work better than the old ones. I also swapped the slides (they looked terrible) for some out of a spare set of carbs.
