Too rich
Re: Too rich
4 months 2 weeks ago
#34791
Further to the "Too Rich" and Sooty" condition".  When you "rebuilt" the carbs, did you remove the "Coaster Enricher piston/diaphragm"  If the answer is NO....given the bikes age, then there is the real possibility that the Coater Enrichment Pistons are all "gummed-up" and stuck in the closed position. (This cuts off the supplement mixing-air circuit)   That will  cause your "rich" mixture.  Leave the "guts" out and merely replace the cover along with a pliable one piece/solid gasket. to seal this system.  The  Enricher System is not necessary or required and will have no adverse affect. This, along with several other simple mods will increase your fuel mileage with no detriment to performance.
  • baz
  • baz's Avatar
Re: Too rich
#34792
I haven't touched the carburetors yet, except for the needle and float chamber gaskets, which have been replaced. Do you mean the cover with three screws on the sides of each carburetor?
My intention was to get all the spare parts, starting with the brass floats, and then later disassemble the carburetors. In the meantime, I wanted to use the bike a bit to see if there were any other obvious problems.
Re: Too rich
#34794
Yes
  • baz
  • baz's Avatar
Re: Too rich
1 month 3 weeks ago
#34986
Hi everyone—sorry, but work and the heat have kept me away from the bike.
I’ve taken the enricher apart to figure out how to proceed.
Scotch, if I’ve understood correctly, you’re suggesting removing the spring, piston, etc., leaving the cavity empty, and reinstalling the cover with a new, handmade gasket. I’ve come up with two options—which one is best?
Re: Too rich
1 month 3 weeks ago
#34987
Hi Baz.  Either option but I've always made the "Full" type simply because it's easier.  As long as the gasket material is thick enough to be compressed to ensure the tiny vacuum port is sealed.
  • poptheclutch
  • poptheclutch's Avatar Topic Author
Re: Too rich
2 weeks 6 days ago
#35035
It's been awhile since I worked on the 1300, been sidetracked with other projects. My choke plungers did look a little funky, so I sent them to Rob Meggitt (zed1015) in UK. They came back looking great, but unfortunately, the bike is still too rich. BTW coasting enricheners move feely. Not gummed up at all. I think my next course will be replacing the slide diaphragms. The slides seem sluggish to drop when raised by hand. They are 46 years old after all. I had a similar problem on one of my other projects a 98 KZ1000 Police. New diaphragms fixed it. Any thoughts ?
