Float Height Settings............Again !
#28184
It would appear the K Workshop Manual is misleading when it describes the point float heights should be measured from ?
The tollerance is between 6.5 and 8.5mm BELOW the measuring point (so 7.5mm is a good mid way point)................but WHICH measuring point A or B or C ??
Can someone who has done this recently confirm this please as I have always measured from C but maybe wrong ?
Last edit: 5 years 11 months ago by strate6.
Re: Float Height Settings............Again !
#28185
seems pretty straight forward to me. "From the bottom edge of the carburetor body" which from your diagram is "B"
#28186
Thanks Kawboy................if only it was a straight forward as that !
See a post by Scotch below, which states very differently !
Interested to hear your comments ?
#28187
The red line indicates aprrox. 7.5mm as does the Green line in the 2nd photo
Last edit: 5 years 11 months ago by scotch.
#28188
Thank you Scotch.
So what is the YELLOW Line in the 2nd photo ?
#28189
That photo was submitted by someone else some time ago. Their yellow line corresponds to the fuel level in their site tube.......which is too high.
