Float Height Settings............Again !
Re: Float Height Settings............Again !
#28190
Ahhhh, I see now.
That was the part that threw me and others !
Also the position of the GREEN Line in your image appears to be much more than 7.5mm down than when I have measured mine as seen below.
As a reference the head of the allen bolt shown in your image is approx 6mm high and the GREEN Line is almost level with that. ?
Last edit: 5 years 11 months ago by strate6.
#28192
Scotch and I are saying the same thing. 7.5mm down from the "obvious" half joint, which is not the mating surface of the carb body/gasket/carb bowl since the carb body has a recess for the gasket and a spigot for the carb bowl to align. So maybe in other words "from the lower most machined edge of the carb body"
#28193
Thanks Kawboy and Scotch,
So basically were the 7.5mm point is in my image above ?
I have to ask, as the Green Line in Scotch's image would actullay be more like 9mm below the "obvious" half joint measuring surface as you can see ?
#28196
None the less, the point has been clarified !
