  • stocktoy
  • stocktoy's Avatar
7 years 7 months ago
#23502
Smart idea.
  • propav8r
#23506
My choke seems to be exceedingly touchy. Every time I try to start it with full choke (ambient temp is about 55*F), the bike floods. If I let it sit a few hours and try again with the choke about 1/3-1/4 of the way up it's travel, it starts right up. Is this normal operation?
My understanding of Scotch's choke air mod is that it would make the mixture richer when the choke is activated. Is that incorrect?
#23510
The choke Mod. effectively does "richen" the start fuel. That's the reason it works. It provides adequate fuel to start. There is a Learning Curve with this mod.
The answer over-all is simple. Learn what ever the Start/Choke technique is for your particular bike and forget what you may think is "normal" and ignore what others state "It Should Be" ! :)
The following user(s) said Thank You: propav8r
  • propav8r
#23513
scotch wrote: The choke Mod. effectively does "richen" the start fuel. That's the reason it works. It provides adequate fuel to start. There is a Learning Curve with this mod.
Fair enough. I'll just be careful with the choke on mine then, and avoid full choke.
  • propav8r
#23544
Took it out for a nice ride on the backroads near my house last night. Not tagged yet, and the plan was to just pop over to the gas station and fill up, but you know how that goes.
I'm really going to enjoy this thing. Turbine smooth, gobs of power, everything just works right like it should!
I did have some trouble finding neutral, but I think that's just because my clutch cable is too loose. I have quite a bit of free play before it starts to disengage the clutch.
I am wondering about the fuel tank vent though...the vent hose from the cap to under the bike is clear, the vent passage through the cap is clear, but it's still pushing pressure out the keyhole and main seal when the fuel starts to warm up and expand. Maybe it's the internal o-rings around the lock cylinders being dried out?
  • stocktoy
  • stocktoy's Avatar
#23546
check that the nipple on the gas cap isn't pinching the O-ring on the top of the tank that can sometimes cause a problem
Time to create page: 0.253 seconds
