Yellow Perils Up-date
Re: Yellow Perils Up-date
10 years 2 months ago
Now that will keep you out of mischief for a while mate.........and even more excuses to be frequestly visiting the "man-cave" for a while !
My missus calls my garage the "man-cave"............I call hers the house !!
The following user(s) said Thank You: Mark
- Mark
OK for those who haven't removed or refitted an engine on a complete strip down, this is the easiest way to do it, engine on its side clear of the floor with wooden chocks below, lay the frame straight over and drop in 2 of your mounting bolts. This is now the end of Yellow Peril and will blossom into a totally different creature. Hard Work more than worth it on the way now. Yep Pete will be busy in there no excuses to make though the cave is the place can spend weeks in there in a happy state of mind lol
Attachment not found
Last edit: 10 years 2 months ago by Mark. Reason: add more text
- Mark
OK you must all be getting bored with this by now, but todays progress, looks like I have been slacking was going to put it on 2 wheels today but hey ho tomorrow is another day
- charlie9670
Keep the pics coming Mark, these are ones I'll be looking at in the future when either mine is all in bits or I've got another one in baskets
- Mark
10 years 2 months agoThere's some good knowledge in the UK amongst our small group which includes yourself. It's good to be able to help each other out, the more you do the more you learn and as you know you have to a dam lot on these tempremental dinosaurscharlie9670 wrote: Keep the pics coming Mark, these are ones I'll be looking at in the future when either mine is all in bits or I've got another one in baskets
- Mark
10 years 2 months ago - 10 years 2 months agoMark wrote:There's some good knowledge in the UK amongst our small group which includes yourself. It's good to be able to help each other out, the more you do the more you learn and as you know you have to a dam lot on these tempremental dinosaurscharlie9670 wrote: Keep the pics coming Mark, these are ones I'll be looking at in the future when either mine is all in bits or I've got another one in baskets
OK latest including a reminder of where we were 6 weeks ago to show the difference. will be dropping a front wheel on tomorrow temp, till I re-furb and re-tyre another. Will be stopping when that is on and re-visiting ensuring all is torqued correctly etc. Next task will be when the Sump Gasket arrives is to fill with oil and coolant and re-check camshaft, ignition timing and valve clearances, don't want to have to be pulling things off at a later date to rectify, on completion of that I will spin the motor and do a compression test just to make sure all is good. Am trying to be logical in my thought process and hold back from rushing forward. Hope these pics and previous are of help to others.
Last edit: 10 years 2 months ago by Mark. Reason: insert pics
Time to create page: 0.239 seconds
