1986 ZG1300
  • rickster
  • rickster's Avatar
Re: 1986 ZG1300
10 years 8 months ago
#11190
Awesome work nice one ;)
  • Tonto
  • Tonto's Avatar
Re: 1986 ZG1300
#11191
Top job Ian, that looks impressive work.
I get nervous about something as basic as fixing the starter clutch or changing the CCT :whistle:
Cheers Tim
  • Away
Re: 1986 ZG1300
#11193
kwak1261 wrote: thats enough taking it to bits, time to start putting it back together, the frame tubes were clean and free from rust internally.
doner frame from Mark In Torquay Thank you B) , just got to make up a few dowels to insert into the tubes
then i can start welding it back together
powder coaters booked for next week.
Nice!! I see by your setup you've got some pipefitting/welding experience. Tig welding or Mig? I love my Thermal Arc 186 with pulse tig. I modified a rad fan housing which is .032" sheetmetal and tigged it all up.
Last edit: 10 years 8 months ago by Kawboy. Reason: spelling
  • kwak1261
  • kwak1261's Avatar Topic Author
Re: 1986 ZG1300
10 years 7 months ago
#11203
Got a nice little weldstar TIG, ideal for this sort of thing. the only issue i can see will be the bottom joint
where i get close to the original weld. could pick up a bit of contamination ill turn the pulse on to help.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • kwak1261
Re: 1986 ZG1300
#11338
bought myself an ultrasonic cleaner, very pleased, should have bought one years ago.
stripped the injector bodies and gave them a few sessions in the tank.
got a spare set of carbs for the A5 going in next.
Z1261J GS1000S
Vmax1200 XT500
  • kwak1261
Re: 1986 ZG1300
#11363
when i bought this bike it came with a set of carbs. apparently they had problems with the DFI
and so tried a set of carbs to see if it would run any better but couldnt get them to hold petrol let alone run the bike.
this is why the bike had been left.
well i thought i would pull the said carbs to bits and put them through the ultrasonic cleaner, at least they would do as a spare set for the A5
well this is what i found inside.
looks like a bit of silicon to hold the main jet in and as for the condition inside im not surprised they leaked..
Z1261J GS1000S
Vmax1200 XT500
Time to create page: 0.245 seconds
