1986 ZG1300
  • kwak1261
  • kwak1261's Avatar Topic Author
Re: 1986 ZG1300
10 years 8 months ago
#11041
it appears that i have an oil pipe running into the back of the camchain tensioner,
does this solve the problem of the tensioner letting the chain go slack ?
if not would it be a issue to replace it with an APE manual tensioner and just block of the oil pipe.
i could bore a hole through the new bolt and replace the oil pipe if needed.
any ideas..? Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • kwak1261
Re: 1986 ZG1300
#11104
got the water pump and thermostat housings off, both a useless, the expanding bypass pipe has cracked both parts
attacked the swing arm to remove it from the frame.
i love what it says in the book to remove the pins. insert a 5 mm bolt in the center and pull. :woohoo: :woohoo: yeh right
the replacements will have an 8mm thread so that a slide hammer can be inserted.
Z1261J GS1000S
Vmax1200 XT500
Re: 1986 ZG1300
#11105
A shame to see that this bike has suffered so much from neglect. But I'm sure you will make a gem out of it - and what a sense of achievement you will have!
I'm curious about that cam chain tensioner. I remember reading that the injec ted models had that oil feed to the tensioner, but what does it do?
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
Re: 1986 ZG1300
#11106
I have an '84 ZG & mine doesn't have that oil pipe to the CCT. I seem to remember that the later fuel-injected bikes (Voyager included) had that system, where the CCT is tensioned according to oil pressure.
  • kwak1261
Re: 1986 ZG1300
#11107
Phil wrote: system, where the CCT is tensioned according to oil pressure.
wow thats a novel idea, ok as long as you have good oil pressure.
ill be swapping it for and older type with a back stop .
thanks Phil.
Z1261J GS1000S
Vmax1200 XT500
  • rickster
  • rickster's Avatar
Re: 1986 ZG1300
#11111
Hey kwak hope the rebuild goes well you got any leads on the bits you need ????
