1983 ZN1300 Street build.
- Phil
- 1984 ZG1300-A1 DFI
Re: 1983 ZN1300 Street build.
11 years 1 month ago - 11 years 1 month agoaus_z1300 wrote:Tyler wrote: As far as the aftermarket adjustable fuel pressure regulator... yeah that is the right way to do it. Lots of people have used them on project bikes and cars of all flavors. A number of guys use electric pumps and adjustable regulators over on KZrider for various projects with good results. That is pretty simple and dependable mod.
Your assumption about the carburetors is a bit too simple. The 1300 is fed with six 33mm chokes for a reason. Your analysis of one cylinder and then the other is somewhat valid at low RPM's but as engine speed increases the flow becomes more steady and the pressure drop through the venturi becomes constant, at that point your small 3 carb set-up will fall flat on its face. A stock bike runs all the way to redline at WOT, so your 3 carb setup would have the equivalent pressure drop of a 1/2 throttle or less... the engine won't get enough air. Your could use three 60mm throttle bodies or something of similar size. That may prove advantageous at high rpm but prove unstable at slower speeds.
You ZN is fuel injection system is not all too complicated to re-make harness for, or use a generic controller to fire the stock injectors. Or even modify the throttle bodies to install aftermarket injectors. Those options would be much easier IMO.
I'll remember that logic. other poeople on the internet have done it so it's ok. Hey it's running too lean lets just put the choke on that will fix it . The only way to do it properly is with a programmabe ecu and a lot of hours road and dyno tuning. Or reprogramming the factory ecu That's if anyone has been smart enough to hack it yet. Like i said before rising rate rubbish is a band aid not a solution and fuel mixtures will be all over the shop dyno tuning is never the entire solution to a good tune. ANd last of all The majority of tuners are dodgy they throw it on a dyno tune the wide open throttle areas get you a silly figure with no load and send you on your way.
Well that's quite a sweeping generalisation, do you have hard proof of the accusation that "the majority of tuners are dodgy"? Or the adjustable fuel pressure regulators sold by respected tuning companies with years of experience is "rising rate rubbish"? You're not one of those conspiracy theorists are you lol?
Last edit: 11 years 1 month ago by Phil.
The following user(s) said Thank You: Nick89
- aus_z1300
11 years 1 month ago - 11 years 1 month agoPhil wrote:aus_z1300 wrote:Tyler wrote: As far as the aftermarket adjustable fuel pressure regulator... yeah that is the right way to do it. Lots of people have used them on project bikes and cars of all flavors. A number of guys use electric pumps and adjustable regulators over on KZrider for various projects with good results. That is pretty simple and dependable mod.
I have seen for myself the damage done by dodgy tunes and rising rate rubbish as a substitute.
In this scenario The rising rate fuel reg is being used to add more or less fuel to compensate and is incapable of producing the right amounts where and when it's needed it is that simple .If a rising rate fuel reg is used in conjunction with a proper tune On lets say an engine that needs more fuel then the factory injectors are capable of supplying at the standard pressure It would be ok.But like i said before it is not a substitute for a tune it's a just dodgy way to go about it . Go and ask a reputable tuner that has been around for more then 5 seconds his opinion.I have told you mine but you obviously think you know better and I have no more time for ignorance go and educate yourself on the subject.
Last edit: 11 years 1 month ago by aus_z1300.
- Nick89
Just a small update.
Got the Lathe running again, New motor!
Also got a new machine for the garage. A 3 axis CNC mill!
Found the ninja 250 wiring harness I had lying around.
Unfortunately the old ZN1300 harness is extremely dry-rotted due to the bike sitting out in the 119F/ 48C weather here in the Las Vegas desert.
I picked up some original KZ1300 Carbs and will be using them in the mean time.
I will be keeping the throttle bodies/injectors for the future if I decide to spend 600-900 on a Mega squirt system.
Last edit: 11 years 1 month ago by Nick89.
- Phil
11 years 1 month ago - 11 years 1 month agoaus_z1300 wrote:Phil wrote:aus_z1300 wrote:Tyler wrote: As far as the aftermarket adjustable fuel pressure regulator... yeah that is the right way to do it. Lots of people have used them on project bikes and cars of all flavors. A number of guys use electric pumps and adjustable regulators over on KZrider for various projects with good results. That is pretty simple and dependable mod.
And as I said concrete proof please, not just hearsay :whistle:
- zed_thirteen
A 3 axis CNC Mill - you may just be my new best friend
- aus_z1300
11 years 1 month ago - 11 years 1 month agoPhil wrote:aus_z1300 wrote:Phil wrote:aus_z1300 wrote:Tyler wrote: As far as the aftermarket adjustable fuel pressure regulator... yeah that is the right way to do it. Lots of people have used them on project bikes and cars of all flavors. A number of guys use electric pumps and adjustable regulators over on KZrider for various projects with good results. That is pretty simple and dependable mod.
Did you educate yourself No. DId you supply a log with wide band 02 readings on a street ride No.Go get your own proof I know I am right and you obviously can't comprehend what i am saying and need proof so go get it.Or as i said call a decent tuner and not a 1/4 mile cowboy and ask him I bet his first response will be laughter .But Because your so ignorant I am betting you do none of the above mentioned and you'll come back with more stupidity.
