Automotive Equivalent for Thermostat
- rdurost
6 years 7 months ago
What's the automotive equivalent of an '82 KZ1300 thermostat? There's an old topic that says it's a Mitsubishi Eclipse, 2006-2009, but the flange diameter is wrong. I believe it should be 2" diameter, and the Mitsubishi is 2.2".
Thanks.
Richard
Thanks.
Richard
Re: Automotive Equivalent for Thermostat
Not sure if I'm thinking of the 1300 thermostat or not but there was a thread I read where the poster ground down the outer edge of the automotive thermostat to the required dia
Be careful. Remember OEM tstat has two modes... warmup and normal, a 2-stage thermostat. I found a replacement that claimed to be OEM correct but it wasn't.. Single vs. dual stage. So the motor overheated.
6 years 7 months agodcarver220b wrote: Be careful. Remember OEM tstat has two modes... warmup and normal, .
Isn't that how every thermostat works?
- rdurost
6 years 1 day ago
(I know I'm resurrecting an old post, but...)
Not necessarily. For example the Cadillac 472/500 engines use a thermostat that has an extension on the bottom that moves with the main "valve," so when the engine is stone cold, the extension blocks a port under the thermostat, and 100% of the water goes right back to the engine so it warms up more quickly. I think that's what the "dual mode" thing is about.
6 years 17 hours ago
