Sub Alternator Connector Location.
- Bar
Re: Sub Alternator Connector Location.
6 years 1 month agoBucko wrote: Thanks Bar. Will check that out. It's the 3 pin connector that is part of the reason why I couldn't find it. Is the "small bracket with two relays " the bracket that is screwed into the frame and also holds the sub R/R?
Yes, this is the one, see pictures
they are not the best but this is what I have
1984 Kawasaki Voyager
2002 Honda CBR954
2002 Honda CBR954
Thanks for posting the pictures.
Mystery solved. The 3 pin connector had been replaced with 3 individual bullet connectors that were completely burnt, corroded and welded together. I replaced them with a 4 pin connector as I didn't have any 3 pin in 6.3mm size. Will replace at some point in the future.
Interesting discussion: which connector type, bullet vs spade, is rated for higher current. I assume it's the spade but will need to check.
Can you post a close-up picture of the 3 pin connector so I know what to look for in a replacement?. Thanks.
Last edit: 6 years 1 month ago by Bucko.
- Bar
6 years 1 month ago
you can check this link I found, look like they have everything
www.cycleterminal.com/250-connectors.html#SC250
below is the 3 pin connector
2002 Honda CBR954
2002 Honda CBR954
The following user(s) said Thank You: Bucko, zed_thirteen, stocktoy, Kawboy
Ahh. That clears up some confusion. Thanks.
- stocktoy
6 years 1 month ago
Man I wish I knew about this terminal site years ago
Thanks "Bar" for the link (abet a few years too late lol)
I ended up ordering the connectors from Eastern Beaver in Japan. I used them before and their shipping has been (for whatever reason) faster than from the US. In addition they send via 'the mail' (airmail actually) so I won't get dinged with (or very little) a brokerage fee like I do with the other courier companies..
