Diaphram washers missing.?
  • Tad
  • Tad's Avatar Topic Author
Re: Diaphram washers missing.?
#24716
Thanks guys. Great help. Bike runs crap terrible starting and when it does some cylinders not firing.Lots of popping etc Have started on carbs. Ripped apart and surprisingly clean. All alley are clear and show carb cleaner running through but all cleaned anyway. When i insert these washers and rebuild i am hoping it will help. Then on to coil checks, new plugs and leads, and shim checks. Hopefully that will sort it and then i can start sripping the paint off the engine for repaint.
Tad
Last edit: 6 years 10 months ago by Tad.
#24718
Nope KB, it wasn't me. I had all the washers.
  • zed_thirteen
  • zed_thirteen's Avatar
#24720
Kawboy wrote: I know someone on the site had lost one and I made him up one and sent it to him. Maybe it was you Stan?
That was to me Kawboy and I'm very grateful - thanks
  • Tad
#24809
Stan. Sorry just realised i didnt tell you i recieved the. Thanks mate. 3 days from canada to me. Great
Tad
#24810
Thanks guys. Great help. Bike runs crap terrible starting and when it does some cylinders not firing. Lots of popping etc. Have started on carbs. Ripped apart and surprisingly clean. All alley are clear and show carb cleaner running through but all cleaned anyway. When i insert these washers and rebuild i am hoping it will help.
Going to burst your bubble - These spacers have nothing to do with the idle problems.
Difficulty starting? "Choke Air Modification" should deal with this!
Not all cyl's firing - lots of "popping" Typically 3 things: 1) Regardless of how clean the carbs look you've got a blockage somewhere. "The Cleaning Tool" deals with this and is the only method that can ! 2) Brass Idle-jets are degraded, disrupting a uniform flow of fuel/air - replace with new. 3) "Pilot-Needles" are damaged -Tips are bent and or "mushroomed" from being dropped ! In this case they are garbage - replace with new.
Last edit: 6 years 10 months ago by scotch.
#24811
Great! I hope with the carb rack clean and back in one piece the bike will be back to it's glory! :)
