  • McBoney
6 years 10 months ago
#25235
Kawboy wrote: i keep mentioning this over and over and over- There are FAKE Shindengen reg/rect's out there and especially on FleeBay. If you go this route go to www.roadstercycle.com and get the real deal.
I have seen the youtube videos.. thanks for the warning.
  • zed_thirteen
  • zed_thirteen's Avatar
#25236
I can confirm there are lots of fakes - I think almost everything on eBay is a fake. the one I bought before doing thorough research was charging my battery at 17v to 18v.
None of the fakes have copied the exact cooling fin pattern of the original Shindengen part. They all look the same until you look closely at the number of fins and the breaks along certain fins. this is probably to avoid being sued for patent or copyright issues
I bought a second hand genuine one from a breakers that came of a BMW - after studying the pictures very carefully!
Last edit: 6 years 10 months ago by zed_thirteen.
  • tackelhappy
  • tackelhappy's Avatar
#25238
Offline
Platinum Sixer
Thank you received: 226
tacklehappy - I missed it or just forgot.. You're in BC?
That's correct Stan South Okanagan Valley.
  • McBoney
#25240
Right, I mounted the headlight..... I'm not sure... I think it may be too big!
Also, not sure about the mounting. Currently I have it on the bracket that supports the fairing, so it doesn't turn with the forks. It may be better if I get two side brackets and mount them onto the forks...
Anyway, This is how it looks.
Last edit: 6 years 10 months ago by McBoney.
  • Neville
  • Neville's Avatar
#25242
I would agree that there are many fake Shindengen regulators on e-bay. There is no such thing as a 'cheap' Shindengen unit. I bought a Shindengen SH775 series unit to address my perennial 79 stator overheat issues and have been very happy with the solution. The only challenge comes in fitting it, as even the 775 is much bigger than the OEM fit unit. I have no idea where one might find space to fit the SH847 as this is enormous.
The 775 does not fit between the battery and the side cover if positioned with the connector facing outwards so I rotated it by 90 degrees with the connector facing the back where it fits with a small clearance between the frame tubes. Pics and wiring diagram below:
Last edit: 6 years 10 months ago by Neville.
The following user(s) said Thank You: zed_thirteen, stocktoy, Kawboy, McBoney
  • McBoney
#25243
Ok, no going back now!
Rear section cut off. Hoop needs a little more alignment and then welding in.
That would then be most of the structural welding done.
On the headlight I have decided to await my new forks and see what the situation is then. These will be 58cm dia so will stick out a little more. Then I'll get the clip-on handlebars and decide whether I'll mount the light with one bottom bracket to the frame (non turning light) or two side brackets to the forks (turning light).
Cut off sections will go to Canada tomorrow.
