ZG1300 project
- Jorgeno
Re: ZG1300 project
6 years 10 months ago
Removed the cylinder block today. The mechanical seal was damaged and the drain hole was clogged. Will deliver head and block to the machine shop tomorrow.
ZG1300 86
ZN1300 86
ZN1300 86
- Jorgeno
Re: ZG1300 project
Oem base gasket is at the moment not available. Some eBay sellers can offer expensive oem gasket, but I don’t trust the quality when they are dispatching it.
Is it ok to use a after market gasket? I see that Z1300.de sells it. I have original cylinder head gasket and preferred to always use oem parts. When it’s possible
ZG1300 86
ZN1300 86
ZN1300 86
- Phil
Re: ZG1300 project
I would use every gasket in an aftermarket kit apart from the cylinder head gasket.
- Jorgeno
Re: ZG1300 project
Thanks! After market base gasket it is then
ZG1300 86
ZN1300 86
ZN1300 86
- Jorgeno
Re: ZG1300 project
6 years 9 months ago
Cylinder block back on, new piston rings, Liska gear, mechanical seal, base gasket, o-rings and new stainless steel water pump shaft
Machine shop is waiting for exhaust guides to finish the cylinder head. Maybe it will be ready next week
ZG1300 86
ZN1300 86
ZN1300 86
Re: ZG1300 project
Nice to see you're making progress. Must feel good !!
