inline fuel filter
  • whistlers mother
  • whistlers mother's Avatar Topic Author
inline fuel filter
8 years 10 months ago
#18067
There doesn't seem much fuel line to fit an inline fuel filter.do you guys use a longer fuel line and re route it? Putting one in as petcock filter disintegrated.
Re: inline fuel filter
#18068
www.kz1300.com/index.php/forum/carburato...rbs-act-up-too#16619
I have mine on a 3" piece of fuel-line directly off the fuel-valve. From there you'll have to determine the best route to the fuel "T". I'm using a double fuel feed so my routing will be different from yours. I also use the spring-clamps supplied with the filter. Used to hate them but they are perfect (in my opinion) for this application. Screw clamps will work but I find that the small diameter required doesn't pull in the clamp evenly and will potentially/eventually, chew-up the line.
Last edit: 8 years 10 months ago by scotch.
