KZ1300 SIDE SWITCH REMOVAL
Re: KZ1300 SIDE SWITCH REMOVAL
8 years 11 months ago
#17745
It's more likely that the switch was left in the PARK position and the park lights drained the battery. Otherwise it's OFF or RUN -which simply supplies power to the main switch via the 30 amp main fuse. If the battery is being drained otherwise then it would have to be further into the harness, past the main switch.
  • rdbhere2
  • rdbhere2's Avatar Topic Author
#17753
I removed the side switch, connected the white and white/blk wires to bypass the side main switch and i srill have a 2.51 volt drain on the battery with the top main switch in the off position.
  • rdbhere2
#17754
If i disconnect my voltage regulator red wire or blk/white wire the drain voltage goes to 0 volts. Nice!
