Carb versus DFI fuel tanks
- Fraserc
9 years 5 days ago
Can anyone confirm that a DFI fuel tank will fit an early carb (A1) bike. I know I will have to blank off the return inlet but anything else ??
Re: Carb versus DFI fuel tanks
9 years 3 days agoSorry I can't help you out so I'm posting to raise your question back up to the membership. Anybody got an answer for Fraserc ?????Fraserc wrote: Can anyone confirm that a DFI fuel tank will fit an early carb (A1) bike. I know I will have to blank off the return inlet but anything else ??
The following user(s) said Thank You: Fraserc
- McZee
9 years 3 days ago
Wish I could help you with this Fraserc. But without seeing the two types together there's no way to tell. At a guess I wouldn't think they would be significantly different.
- Haggler
9 years 3 days ago - 9 years 3 days ago
Just been looking at photos of the underside of both tanks. The injected one does have a return pipe you would have to blank (no worries there) but the sender unit for fuel level is a different shape (carb one is round ) where injected one is round with the sides cut off if you get what I mean so you would need the right sender unit. As far as I know all clocks are same but you might ave to modify the wiring for the new sender
eBay item number:
351819831434
eBay item number:
202081496338
These are the two listings with the pics I was looking at (you will need to scroll along to the right photos)
Hope this helps
eBay item number:
351819831434
eBay item number:
202081496338
Hope this helps
Last edit: 9 years 3 days ago by Haggler.
