Fuel Pressure
  • wess.vic
  • wess.vic's Avatar Topic Author
Fuel Pressure
10 years 1 month ago
#14278
My bike has been running great and I've been riding all summer. The only problem I have is when I leave thre gas on it pushes fuel into cyclinder one and when I need to start it I have to open the throttle and let air come in to burn it out. I had this problem without and with the original fuel valve. I also have the brass floats and adjusted correctly. I use a pingel fuel valve f that means anything. Does anybody else have this problem and how can it be fixed? I was thinking fuel regulators and was going to buy one but I figured instead of me using trial and error Im sure someone solved this problem.
  • Yaegunp
  • Yaegunp's Avatar
Re: Fuel Pressure
#14279
If I'm not mistaken this happens to all our bikes especially when it is on the side stand, that's why number one gets filled up. only way to avoid this is to remember to turn your petcock to the off position. It's also been reported that if your still using the original petcock fuel can still make its way into the cylinder and some members have installed a second inline cut off valve to stop this.
These previous post may be of interest.
Fuel Overflow
Fuel
You may find the root cause by reading the FAQ section, when you navigate to the Faq section use your browsers search facility and search for 'fuel', you may find your answer there
1983 Z1300 A5 plus Sidecar.
Last edit: 10 years 1 month ago by Yaegunp.
  • Ledkz1300
  • Ledkz1300's Avatar
Re: Fuel Pressure
#14280
You need to not forget to turn the fuel off. Filling up the cylinder with gas can result in a bent connecting rod or worse. If you know the cylinder is filled or partially filled with fuel do not start it. Remove the spark plug and let the fuel blow out the hole. If there is too much fuel and you don't do this you could have a catastrophic failure.
There are other fixes but not forgetting is the most important.
Re: Fuel Pressure
#14281
There's an oring on the float needle seat to the carburetor body that could be passing on #1 carburetor. If it is passing, it would explain your problem.
The other issue that come up many times before is the retainer spring between the float needle and the float. Some members have found that the aftermarket kits have a slightly different spring and it can cause the float needle to bind in the float needle seat.
