Oil light
  • Scorpio2016
  • Scorpio2016's Avatar Topic Author
Oil light
10 years 3 months ago
#13332
If I start the bike after it sits for a while on the side stand the oil light will stay on. But if I shut it off and restart it the light goes out like it should. I just changed the oil and filter and level is correct. Could this be an electrical issue?
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Oil light
#13333
Does your model have the unreliable oil level switch? Not sure how it works but it also illuminated the low oil pressure red idiot light.
  • Scorpio2016
Re: Oil light
#13335
Hmmm...don't know but I'll check it out.
  • z13phil
  • z13phil's Avatar
Re: Oil light
#13340
I've had this problem so just fitted a 80psi pressure gauge with hose to the pressure switch outlet. Well within workshop manual tolerances. So it's a faulty pressure switch.
  • hillsy
  • hillsy's Avatar
Re: Oil light
#13342
My oil pressure switch wasn't working so I changed it out for a car one.
I know this is pretty much the opposite of what is happening with you, but they are cheap enough to replace in case it's also your problem.
Thread is over here: www.kz1300.com/index.php/forum/welcome-m...-it-be-cleaned-fixed
Last edit: 10 years 3 months ago by hillsy.
  • Scorpio2016
Re: Oil light
#13347
I will be checking into the car pressure switch if cleaning it with carb cleaner doesn't do the trick. Many thanks for the heads up.
