79 rear master cylinder rebuild kit
- Jmthemailman
10 years 3 months ago
Could someone please direct me to a place where I can buy a rear master cylinder rebuild kit for a 1979 KZ 1300 mine is leaking I'm assuming I need a rebuild kit I can find the front but I cannot find the rear or are there any other models that take the same rebuild kit
- kwak1261
Re: 79 rear master cylinder rebuild kit
im not sure what part of the planet you are in, must be a secret.
but if you are in the UK then this kit on Ebay 401113451263 has the same size rubbers as the rear master cylinder
just swap the rubbers as long as the body is clean internally.
Ian
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
The following user(s) said Thank You: Jmthemailman
- Jmthemailman
I'm in the United States! Thanks I'll check those out. I have a leak at the rear master cylinder. Figured I'd just rebuild it. I'll start with the new rubber. Thanks again
- Z1300rider
10 years 2 months ago
Hi, here is mine just rebuilt by Pastparts to an absolutely first class standard for £125 .
- Z1300rider
Sorry, just realised you said master, my rear master was rebuilt by them for about the same price. Basically they machine out the bores, sleeve them in stainless steel and then rebuild them with modern seal kits and a complete visual overhaul into the bargain.
Time to create page: 0.237 seconds
