air system leaking down
  • robert78.5
  • robert78.5's Avatar Topic Author
10 years 4 months ago
#13075
1983 ZN1300, the air builds up in front and rear shocks good, but they leak down in about 30 minutes, i soaped all lines and can not see any bubbles, this has me baffled as both front and rear loose air. The manual says to check bleed air valve. I have searched and can not find the pull string to pull. Any ideas where it might be?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: air system leaking down
#13077
I believe they're referring to the schrader valves. "Pull String"?
  • robert78.5
#13080
yes, the bleed down valve, can not see the pull ring anywhere. Is it hidden ? also if this is leaking would it cause both front and rear shocks to lose air pressure?
Last edit: 10 years 4 months ago by robert78.5.
