Fan Switch temperature Sensor
  • Mark
  • Mark's Avatar Topic Author
11 years 5 days ago
#9702
Hello All,
has anyone made a repair to a Fan Switch Sensor when the connector spade has broken, if so what sort of repair did you do. Has anyone used a self tapping screw to replace the spade and connected a terminal to that.
Attachment not found
  • kza13
  • kza13's Avatar
Re: Fan Switch temperature Sensor
11 years 5 days ago - 11 years 5 days ago
#9704
I used a screwdriver and dug out the sealant around the broken spade connection and got down to a decent area where I just gently soldered on a new spade then just filled around it with a bit of araldite (epoxy resin), good as new, many miles and still working, cheers Pete
Last edit: 11 years 5 days ago by kza13.
The following user(s) said Thank You: Mark
  • Mark
11 years 5 days ago
#9705
Yea Pete sounds good to me, don't intend to scrap them as replacements aren't cheap, have 2 to repair from boxes of bits that I have, so any ideas are good ideas
  • aus_z1300
  • aus_z1300's Avatar
#9708
Sometimes it is a lot cheaper to match it with a commonly used car part.
Not that I have done it with this switch but I have done with heaps of other bike temp oil switches even fan motors on bmw's etc.
Tridon carry quite a few and are available at just about every spare parts shop here in aus.
www.tridon.com.au/products/Tridon/35/483.../thermo-fan-switches
Last edit: 11 years 5 days ago by aus_z1300.
  • kza13
  • kza13's Avatar
11 years 4 days ago
#9711
There was a thread or post somewhere here where someone drilled and tapped out the hole and used a different switch, you just have to make sure it switches on at the right temperature, forget what temp they said it works at sorry
  • aus_z1300
11 years 4 days ago - 11 years 4 days ago
#9713
85 degrees celcius is apparently is what you want.
It's in a thread you started kza
thread
Last edit: 11 years 4 days ago by aus_z1300.
