Steering bearings.
- Richobob
- 1980 A2
Steering bearings.
5 months 1 week ago
Any suggestions for replacement steering bearings in the UK for my 1980 A2 please?
Re: Steering bearings.
5 months 1 week ago
You might try AllBalls bearings...
I'm not a big fan of AB bearings... but tapered is the way to go, and they are available.
With a bit of searching, you might find higher quality FAG or Timkens...
Then again, steering head bearings are under-stressed, not worked hard, and the AB bearings price point is good too.
The key is tapered bearing, not ball bearings.
After years of service, ball bearing will make indents into the races, causing a 'notchy' feeling.
Good luck!
d
Good luck!
d
5 months 1 week ago
I took the bearings to a local auto-parts store where they matched the #'s and provided me with the bearings needed.
- stocktoy
- Away
5 months 1 week ago - 5 months 1 week ago
And don't forget the seals some replacement bearings don't come seals and will let all kinds of crud settle in on the bearings causing problems
Last edit: 5 months 1 week ago by stocktoy. Reason: spelling
5 months 1 week agoGreat add to the post stocktoy!And don't forget the seals some replacement bearings don't come seals and will let all kinds of crud settle in on the bearings causing problems
Time to create page: 0.151 seconds
