rear tire
rear tire
6 years 2 months ago
For what it's worth: I'm waiting for a rear tire to be delivered and thought I'd mention that the 2 best rear tires I've had for mileage and good handling have been Continental. A Continental"1" back in '80 - new when I went across Canada. Bald when I got home - 8,000 kilomters. Had other brands - one only lasted 3000K ( can't remember the make).
Two years ago I put on a Coninental "Conti-motion" 150/70ZR17. 10,984 Kilometers. It wore thru on the last ride but I got my money's worth !.
Re: rear tire
:blink: Never seen a tire worn through to the cords on the side like that! You must go around a lot of corners
Re: rear tire
Here's my rear Voyager tire after a trip of about 10k Kms (approximately 16k Kms total on the tire - not bad for a cheap IRC - think it was IRC - tire that came on the bike when I bought it).
(that bald spot tho :oops: - I know, I'm an idiot - I knew the tread was getting thin but I was getting close to home and I checked it several times over the last few days - it just happened the bare spot was not showing when I checked.
Last edit: 6 years 2 months ago by Bucko.
Re: rear tire
Yes, I like to "corner" (who doesn't) .....but know the limits and back-off from that a bit !
Same situation. Was watching the tire closely as I knew it was getting down. Looked at it at the half-way point on that last little run and it was still OK. I now know there is little if anything under that center groove and will certainly keep that in mind with the new tire.
