Rear Master Cylinder
  • HarryFarrider
  • HarryFarrider's Avatar Topic Author
7 years 6 months ago
#23897
1984 ZG1300A. Rear brake master cylinder is beyond rebuilding - too corroded. Can anyone recommend a suitable replacement cylinder that I can mount inrplace of the original, even if some modification is required? I rarely use the rear brakes, and even then very lightly, so do not need to apply anywhere near the original pressure to the rear caliper cylinders.
  • paulb
  • paulb's Avatar
Re: Rear Master Cylinder
#23899
One of the guys on the English site did a mod quite recently z1300.co.uk i will see if i can find a link
The following user(s) said Thank You: HarryFarrider
  • mizztheman
  • mizztheman's Avatar
#23903
Hi Harry,
This is the conversion I carried out to my master cylinder.
Page 6 & 9.
www.kz1300.com/index.php/forum/bike-proj...ress-so-far?start=30
Regards
Martin
  • HarryFarrider
7 years 5 months ago
#23947
Thanks Martin.
I wondered about the rear brake light - did you add a pressure switch in the line, or did you find a cylinder with a switch built in.
Also, how did you go with the mounting holes. Did you have to make a bracket to mount it ?
A pic of the back of the assembly would be good if you had one.
#23956
Just in case, you can press a new sleeve in. I had it done on the front master cylinder with a stainless sleeve. Works great and lasts forever. Cost was about $100.
  • mizztheman
#23957
Hi Harry,
I was going to fit a pressure switch but the MOT tester didn’t pick it up on the test. Apparently it was only mandatory to have the brake light operated from the rear brake after a certain year. I made some brackets from flat bar to fit the master cylinder to the existing fixings. Sorry no pictures I’m afraid.
