Best fork oil
- Artsagas
Best fork oil
12 years 10 months ago
I have to change the fork seals, as I guess has been a common task for you, folks. What is, in your opinion, the best fork oil -fluid- for our beasts? Thanks a lot!
Arturo
1982 Kawasaki Z1300
1982 Kawasaki Z1300
- RickG
Re: Best fork oil
I have always used Auto trans fluid. I realize that there are specific oils for the job but ATF has always been OK for me and it's about 1/4 of the price of the "real" fork oil.
The following user(s) said Thank You: Artsagas
Re: Best fork oil
yeh same here, good stuff
- tackelhappy
Re: Best fork oil
One option you have with real fork oil is that there are different viscosities which do effect the action of the fork. Depends how much you want to customize the front end feel ..... soft/ harder etc.
- Artsagas
Re: Best fork oil
Thank you all. Regarding fork fluid, what should it be it's weight to keep it as "original" as possible? And how much fluid goes into each fork? Is it an easy job to do? Regards
Arturo
1982 Kawasaki Z1300
1982 Kawasaki Z1300
- Toddh
Re: Best fork oil
ATF can be a good solution and a cost effective one but you would be locked into a single viscosity. With our fork cartridges only requiring a few 100cc's, the cost of fork oil is minimal, plus one can exchange one weight to the next, with the next weight being compatible with the last.
If you start with ATF, and don't like the rebound or dampening, you would need to completely disassemble the forks to purge the ATF out of your cylinders. (If you wanted to go back to standard fork oil.)
Fork oil weights that were factory recommendations in the 70's and early 80's were meant for lighter riders of the day. the 1300 can easily tip the scales over 1,000 to 1,1000 lbs depending on rider/ riders weight with the basic weight of the bike.
One great add to our forks is adding RaceTech (Gold) Fork Emulators. www.racetech.com These are easy to install, with excellent tech support from these guys. (Not overly expensive) Its adding 21st century technology to our 20th century forks. They have a vintage bike area off of their street bike page.
If you choose the standard fork oil route, Bel Ray or PJ1 is a good choice.
When the forks are apart, don't forget to inspect/ replace the head bearings and look at the internal bronze bushings on the lower legs. Plus take some cotton to the upper chrome portion to make sure there is no pitting or damage. If you have an air crossover hose, those can become dry rotted over time, and may need to be replaced.
Regards.
T.
Regards.
T.
Time to create page: 0.300 seconds
