cam chain tensioner??
  • Twinpilot001
  • Twinpilot001's Avatar Topic Author
12 years 5 months ago
has anyone tried// done a conversion on the oem- cam chain tensioner to convert it to a manual type-using the origional tensioner part??
  • Mikez
  • Mikez's Avatar
Re: cam chain tensioner??
it has been done before. My bike had one that was drilled and converted to manual style before I moved to the zx style one.
With the right tools it should be simple to drill and tap your own tensioner with a manual setup. Otherwise a zx style one can be less of a hassle overall and cheaper if you find a used one. Got mine for less than 20 bucks on ebay.
Just make sure to clip the spring 10mm before install :).
  • kwak1261
  • kwak1261's Avatar
My standard one has been modified, it now has a bolt in the end with a lock nut. works fine.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • HotRodSixxer
  • HotRodSixxer's Avatar
Hi, Mike, I did the zx mod that was recommended on the old KZ 1300 site. There was nothing mentioned about clipping the spring. I have yet to get it going after stalling out on my project over 10 yrs ago. I'm back on it again and hope to get it going soon. What is the reason for cutting the spring? Thanks, Jake
  • Mikez
  • Mikez's Avatar
The spring is too stiff for the nylon gears that the chain roll on. Shortens lifespan of those parts considerably.
See:
kz1300.com/index.php/forum/engines/75-fu...rhaul-z1300?start=18
and
z1300.proboards.com/index.cgi?board=tech...n=display&thread=384
The following user(s) said Thank You: HotRodSixxer
  • KzFlames
  • KzFlames's Avatar
How did you set the tension?
Time to create page: 0.116 seconds
